Vic Smeed’s HMS Cossack MM500
Home Forums Build Blogs Vic Smeed’s HMS Cossack MM500
Viewing 25 posts - 1 through 25 (of 384 total)
  • #9783
      Mass Build
        Some of us fancy some light relief with a Mass Build thanks Roger, Tim & Eddie for your encouragement.
        It's not a race but we hope we can build a flottila of Tribal Class destroyers and meet up for a Mass sail at some point in the future 😀
        SARIK sell the plan for £12.50 mainly balsa construction.
        Let us know if your up for it ?
        Kind Regards Ray
        #82775
        Roger Clark
          @rogerclark
          Ooer it's a bit empty in here, kinda echoey. I'm up for it but you mentioned enlarging to 1/96th and I'm not very good at that kind of thing so will there be help offered?
          Roger
          #82776
            The magazine article which accompanied the plan was published in the January 1958 edition of Model Maker. I've attached the text but had to avoid the small page size plan which was also published (whilst the plan is still on sale, I don't think I could show it when someone is trying to earn a living!).
            The scans aren't the best, they were sent to me.
            #82778
              Thanks Tony,
              We will either build at 38" long as drawn by Vic or with the help of a big photo copier enlarge to 48" long giving 1 /96th scale of 1/8" to the foot I like imperial measurements 😀 when I built it last 50 years ago I recall it had the correct lines for the hull.
                @timrowe83142
                Hello Ray
                Before I book some sessions with a chiropractor, how heavy is the 48" model compared to the 38"
                One of the reasons I am a big fan of model aircraft is that even the big ones are light. A recent post talked about a keel weight of 45lb made me weak at the knees.
                It would be something completely new for me and that is why it appeals.
                Looks like there could be 4 of us but I am glad you said it was not a race. With all my other projects it would fill a year easily.
                Count me in.
                Tim R
                #82781
                Eddie Lancaster
                  @eddielancaster
                  I'm not sure about the larger version buy as Tim says I will go with the flow.
                  Eddie.
                  #82782
                    I built one of these around 55 years ago. The original size was manageable as I recall.
                    I'm afraid I don't build warships these days though.
                      Hi Cossacks,
                      I just weighted HMS Diamond which is 48" long only 9 lbs auw 3lbs of ballast, lead ingots in the bilges twin 400's goes well 😀 Cossack is an easier build than plank on frame as the hull base is 2 sheets of 1/2" balsa sheets just the top sides planked. Diamond took 3 years ! ! But John Haynes fittings help.
                      #82785
                        @timrowe83142
                        Hi Ray
                        Appointments cancelled and will get the plan on order.
                        Could be persuaded to go to 48" or 1.219 metres as it would have to be here in Spain and in that case it would be all planked.
                        I have never built a Vic Smeed model although I am a fan and have some of his books. Good time to start then.
                        #82787
                        Eddie Lancaster
                          @eddielancaster
                          Hi. Ray and other Cossacks, plans on order.
                          Eddie.
                          #82788
                          Roger Clark
                            @rogerclark
                            Flippin' eck nobody can call you steady Eddie wink, better put my order in then, Sarick will wonder what's going on!!!
                            Roger (still crook and in plenty paincrying)
                            #82789
                              Morning Cossack's
                              Yes when Eddie flys into action ! Watch this space 😀
                              Any others wishing to have a Go please pipe up ! A sort of self help group for ideas and problem solving.
                              RCM&E forum has a Hawker Fury build on the go at the moment, worth a a look 😁
                              Colin if you have a Go you may feel 55 younger ? Deja Vous at least 😉
                              Will order the plan tomorrow .
                              Edited By Ray Wood 2 on 30/06/2019 11:20:54
                              #82790
                                Sorry Ray, two other projects in hand at the moment which is enough for me! Good luck with the initiative though.
                                Roger Clark
                                  @rogerclark
                                  Plan ordered smiley
                                  Original plans of the Tribal class destroyer: Booklet of general plans, circa 1941. Courtesy of the Historic Naval Ships Association. Might be slow to open (big file)
                                  Roger
                                  Edited By Roger Clark on 30/06/2019 13:34:08
                                  #82792
                                    I will be looking forward to the build . I am tempted to join you but 2 models in progress, and another planned. Workshop being replaced soon so will be busy trying to get a new one up and running.
                                    Good luck
                                    #82793
                                      @timrowe83142
                                      Glad to see you will be building to such detail Roger wink
                                      A great resource for the build and especially for the Rivet Counters.
                                      Nice one. yes
                                        @timrowe83142
                                        Posted by Tim Cooper on 30/06/2019 13:51:10:
                                        Good luck
                                        Be tempted Tim
                                        I bet you would finish before me. I am a slow builder and with lots of projects on the go
                                        Tim R
                                        #82795
                                          Hi Tim,
                                          Thank you for your good wishes for the Cossack build, all the current crew are trying not to think of the many on going projects we all have at various stages 😀
                                          Roger Clark
                                            @rogerclark
                                            Hmmm yes current count including repairs/upgrades = 7!, oh plus the Cossack but does include the Veron Damen Stan tug freebie I collected last week, feeling frustrated crying and evil devil as I can't stand up.
                                            Roger
                                            #82797
                                            Roger Clark
                                              @rogerclark
                                              Tim C, Bigger workshop = more space = room for a Cossack smiley
                                              You know it makes sense laugh
                                              Roger
                                              #82798
                                              Roger Clark
                                                @rogerclark
                                                HMCS Haida, last remaining Tribal class destroyer preserved at Hamilton Ontario.
                                                Anyone want to pay for me to go and take photos for the good of the Cossack group build???? wink
                                                Roger
                                                #82799
                                                Eddie Lancaster
                                                  @eddielancaster
                                                  Deans Marine do a 1/96 model of Cossack, and as my friend in Kent built that boat he has the drawings for all the top works, so we can save a few bob by getting those instead, the next time I visit, sorry Rogersad.
                                                  Eddie.
                                                  #82800
                                                  Roger Clark
                                                    @rogerclark
                                                    Doh! crying
                                                    #82801
                                                      Good evening Cossack's
                                                      Beware the detailed drawing ! The drawings for Diamond from My hobby Store showed loads of bits and bobs, so for that reason I'm sticking with Vic's version of detail, I don't want to spend 3 years on this model. Still have Belfast on the list 😀
