Hi Everybody,
Been one handed again all month as the NHS had another dig around in mi left hand to try and fix the nerves. I’ll know if it worked once I can waggle all the digi bits again.
Anyway, I’ve been playing with mi vape smoke unit and it really looks like it might work. I chucked the battery, switch and LED away and soldered new wires to the heater. The card tube was cut down to length (50mm) and it all put back together with the bottom sealed with hot glue.
The top was just left open.
When connected to the 6v battery it gave an excellent plume of smoke.
Run constantly it lasted for about 30 minutes and used about 1/2 cc of fluid and was easily refilled from a syringe straight into the top. I just used 25% glycerin and distilled water. The £5 I spent on supplies will last me a very long time.
When running constantly, it drew 3.5 amps which I think is too much. However, when pulsed in one second intervals the current stayed below 1.5 amps which I think is a bit more acceptable and the smoke doesn’t have to be switched on all the time. The pulsing also gave a pleasant puff effect which I found ideal. I have a cunning plan for the pulse circuit, the next step.
All for now. Len.:)
