The mighty tug Wattle
Home Forums Build Blogs The mighty tug Wattle
  • This topic has 54 replies, 10 voices, and was last updated 2 months ago by harry smith 1.
Viewing 5 posts - 51 through 55 (of 55 total)
  • #124348
      Well done Mick. The Swan finally emerges from the cardboard box! You should sail it on your lawn now.
      It’s always surprising how much ballast relatively dumpy hulls need, and how shallow the draught is on lighter.models even of a decent size.
      Richard. Envious of that workshop! My ‘kitchen trolly’ is a workmate with a bit of kitchen worktop on top.
      mick east
        @mickeast46851
        Hi Ashley ,that’s one of the things I like about this model is its hull shape. The maiden voyage is scheduled for next Saturday at the club Lake, that’s if the weather gods are kind ( just at the moment we are in a torrential rain /thunderstorm period).
        #124547
          Hi Mick
          What a lovely tug !!!
          That 4 blade prop will make the Brush motor work hard !!!
          I tried a 540 80 turn one a 60mm 4 blade in a tug it got very warm !!!!
          I was only running on 7.2 volts.
          I had a lovely time in Brisbane but that was August last year.
          I will stay down south for the summer in Tassie .
          #124555
          mick east
            @mickeast46851
            I’ve got the same motor battery combo (7.4 lipo) in my trawler and it seems to cope OK with out over heating  . The prop is a 50mm prop so that might make a difference . If it does run hot I will change it for a bigger motor or spin some copper tube around this one and water cool it. I’ll see how it goes
            #124578
              Hi Mick
              Yes the 50mm prop would a lot less load on the motor.
              Hope your test run works out OK, dam nice looking tug.
