Fairmile D
Fairmile D
Home Forums Build Blogs Fairmile D
  • #103695
    Martin Wallace
      @martinwallace15155
      Hi can anyone help me I have brought a fairmile D 1/24 scale 58 inches long,hull with motors and props already fitted but I cannot find any plans for construction of the superstructure in 1/24 scale
      many help would be appreciated
      Martin Wallace
        @martinwallace15155
        Construction plans
        #103711
        John W E
          @johnwe
          hi there if you have a look through Sarik Hobbies website you will find a set of plans for the Fairmile D .
          There is also a gentleman who produced the book, John Lambert, Anatomy of the ship series, The Fairmile 'D' Motor Torpedo Boat – this will give you all the information you need,
          John
          #103721
          Martin Wallace
            @martinwallace15155
            Thanks John for information on that, but I have already tried Sarik Hobbies the only plans they have of fairmile D are model that’s 38 inches long, and the other plans that they do is a lot bigger than 1/24 scale I have also brought the Jhon lambert book yes it’s a very good book plenty of information which helps, but I still cannot get hold of a set of building plans mainly for the superstructure so I get the build spot on
            #103724
              Hi Martin,
              If you buy the 38" plan it's quite straight forward to have it reprinted at 58" at a repro shop , I did this with Vic Smeeds HMS Cossack to make it 1/96th scale.
