Roof trimmed and sanded to all sides and the top has been given a preliminary sanding with the PermaGrit.
Part of the twist was found to be due to a build up of saw dust
and most of the problem is due to bowing front and rear along the sides – looks worse than it actually is. As said the cabin is a pretty good fit so I've put a saw cut in each cockpit side, just behind the cabin, so that the cockpit sides can be "bent" down to touch the top of the deck. Fitting the superstructure hasn't been made any easier of course by having a curved deck. When clamping the cabin sides to the coaming there was a cracking sound – the coaming is only 1.6mm thick and had cracked up by the window frame. Soon fixed with some reinforcing pieces of coaming.
A start was then made on the cockpit. I'd previously cut out the cockpit bottom and sides and just needed to sand 2mm from each side of the bottom to allow for the thickness of the sides and cut a bit off the end of the bottom at the cabin end so that it would drop into the hull. I then tacked the pieces together at the transom end with cyano and once set clamped that area. I then glued the rest of the side and bottom joints with a/resin, clamped and set aside overnight.
I'd decided that it was best to deal with the construction of the cockpit at the transom end first due to the envisioned difficulty of making everything fit as it should. The sides and bottom by the cabin have been left longer so that they can be sanded back to size.
So I then moved onto the transom and sanded a piece of mahogany strip to shape having marked it out using the card template for the cockpit bottom. I also reduced the section of the capping by sanding the top to a slight angle and rounding off the rear corner. As the top of the transom is slightly curved I also sanded the underside of the capping to get a good fit.
To locate the top of the 2mm ply forming the inside of the transom/rear of the cockpit I've used a brass channel, bought previously for the purpose. To enable it to be bent easily I made numerous saw cuts and then glued it in place with 5 minute epoxy.
Edited By Chris Fellows on 08/04/2019 18:59:31
