Cant frames are widely used in full sized shipbuilding and have been so going right back to wooden ships. The hydrostatic and wave motion forces on a ship’s shell plating or planking act normal to to the surface so from a structural point of view having a stiffener on the other side also normal to the surfaces is efficient.
The other reason is practical. As the bow and stern sweep around to the centreline, the frame has an open side and a closed side in relation to the shell. The open side is an obtuse angle and in the case of riveting it is easy to open up an angle bar and get access for riveting. On the closed side the angle forming is much more difficult and it could be impossible to get access to work the rivets.
The same applies for welding if it is required on both sides. It is easy to weld on the open side but impossible to get a full penetration weld on the closed side.
On tradition shipbuilding it saved making big bevels which was wasteful of material and labour. The lofting was a bit more difficult but they were clever at that and Chris is too.
