Remember this one!!! Last post over 2.5 years ago!
But the plan was to get all 5 builds to the painting stage which I have done. Though it was earlier in the year and summer delayed progress.
I was just going to paint the hulls initially on the Huntress and H28 but decided I might as well do this one as well as it is easier with no strakes. It had coats of One UP primer undercoat as per the other hulls, but unlike with those it didn't need any additional spot priming yesterday but just a bit more sanding with 400 grit silicone-carbide paper.
So today I tackled this one first and applied a coat of Toplac Plus topcoat to the hull bottom. After some frustration with the primer undercoat (see Huntress thread) I have to say it went on beautifully with my good quality brush. The paint is so much thinner, flows nicely and tolerates over brushing as it is slower drying than the One UP. Even after one coat the finish is lovely and high gloss. Sanding scratches are visible under close scrutiny but multiple coats and sanding with a finer grit should sort that.
I've done plenty of household painting but this is the first time I've painted a model with top quality brush paint and as such I was going to have to go through a learning curve. Maybe I should have done it on one hull first rather than three though! With the other two I shall certainly thin the primer undercoat down a bit.
I also gave the hull sides of the Huntress their first coat of gloss.
